EFK stack install
A project log for Project Dandelion
Ubuntu 21.10 with microk8s/1.21.6 on Raspberry Pi 4
carboncycleCarbonCycle 10/25/2020 at 06:290 Comments
Kyle            - Pi 4b/8G  NVMe
Stan           - Pi 4b/8G  NVMe
Cartman    - Pi 4b/8G  NVMe
Kenny        - Pi 4b/8G  500G 7200rpm spinning rust
Butters      - Pi 4b/8G  500G  Crucial flash sata
A console node for serial ports - Pi 3b+
K8console  - Pi 3B+  MicroSD
Now there is a need for log aggregation.   This design will use Fluentd on the OS and Fluent-bit on the microk8s cluster.  The log destination will be to a Elasticsearch node with Kibana installed.
Installed another Pi 4 / 4G with the new Ubuntu 20.10 64 bit release ( no desktop).  This release does not require the MicroSD card to boot - so I've used a SATA flash disk here.
Adding this new node that runs Elasticsearch and Kibana.
Ike           - Pi 4b/4G  240G Crucial flash sata
