Core HA nodes are up.
A project log for Project Dandelion
Ubuntu 21.10 with microk8s/1.21.6 on Raspberry Pi 4
carboncycleCarbonCycle 10/17/2020 at 01:380 Comments
Following the instructions here:  Adding nodes
ubuntu@Node-1:~$ microk8s kubectl get all --all-namespaces -o=wide
NAMESPACE     NAME                                          READY   STATUS    RESTARTS   AGE     IP             NODE     NOMINATED NODE   READINESS GATES
ingress       pod/nginx-ingress-microk8s-controller-4tb5s   1/1     Running   1          6h33m   192.168.1.40   node-3   <none>           <none>
kube-system   pod/calico-node-ggdrf                         1/1     Running   1          3d4h    192.168.1.40   node-3   <none>           <none>
ingress       pod/nginx-ingress-microk8s-controller-kj8lt   1/1     Running   2          6h33m   192.168.1.41   node-2   <none>           <none>
kube-system   pod/hostpath-provisioner-976f6d665-j7sgl      1/1     Running   1          3d19h   10.1.247.2     node-2   <none>           <none>
kube-system   pod/calico-node-gh6jz                         1/1     Running   1          3d20h   192.168.1.41   node-2   <none>           <none>
ingress       pod/nginx-ingress-microk8s-controller-hkxqd   1/1     Running   1          6h33m   192.168.1.30   node-1   <none>           <none>
kube-system   pod/calico-node-449m7                         1/1     Running   1          3d20h   192.168.1.30   node-1   <none>           <none>
kube-system   pod/calico-kube-controllers-847c8c99d-9nx7p   1/1     Running   1          3d20h   10.1.84.132    node-1   <none>           <none>
kube-system   pod/coredns-86f78bb79c-ngbnx                  1/1     Running   1          3d20h   10.1.84.131    node-1   <none>           <none>
NAMESPACE     NAME                 TYPE        CLUSTER-IP      EXTERNAL-IP   PORT(S)                  AGE     SELECTOR
default       service/kubernetes   ClusterIP   10.152.183.1    <none>        443/TCP                  3d20h   <none>
kube-system   service/kube-dns     ClusterIP   10.152.183.10   <none>        53/UDP,53/TCP,9153/TCP   3d20h   k8s-app=kube-dns
NAMESPACE     NAME                                               DESIRED   CURRENT   READY   UP-TO-DATE   AVAILABLE   NODE SELECTOR            AGE     CONTAINERS               IMAGES        SELECTOR
ingress       daemonset.apps/nginx-ingress-microk8s-controller   3         3         3       3            3           <none>                   6h33m   nginx-ingress-microk8s   quay.io/kubernetes-ingress-controller/nginx-ingress-controller:0.33.0   name=nginx-ingress-microk8s
kube-system   daemonset.apps/calico-node                         3         3         3       3            3           kubernetes.io/os=linux   3d20h   calico-node              calico/node:v3.13.2                                                     k8s-app=calico-node
NAMESPACE     NAME                                      READY   UP-TO-DATE   AVAILABLE   AGE     CONTAINERS                IMAGES                                    SELECTOR
kube-system   deployment.apps/hostpath-provisioner      1/1     1            1           3d19h   hostpath-provisioner      cdkbot/hostpath-provisioner-arm64:1.0.0   k8s-app=hostpath-provisioner
kube-system   deployment.apps/calico-kube-controllers   1/1     1            1           3d20h   calico-kube-controllers   calico/kube-controllers:v3.13.2           k8s-app=calico-kube-controllers
kube-system   deployment.apps/coredns                   1/1     1            1           3d20h   coredns                   coredns/coredns:1.6.6                     k8s-app=kube-dns
NAMESPACE     NAME                                                DESIRED   CURRENT   READY   AGE     CONTAINERS                IMAGES                                    SELECTOR
kube-system   replicaset.apps/hostpath-provisioner-976f6d665      1         1         1       3d19h   hostpath-provisioner      cdkbot/hostpath-provisioner-arm64:1.0.0   k8s-app=hostpath-provisioner,pod-template-hash=976f6d665
kube-system   replicaset.apps/calico-kube-controllers-847c8c99d   1         1         1       3d20h   calico-kube-controllers   calico/kube-controllers:v3.13.2           k8s-app=calico-kube-controllers,pod-template-hash=847c8c99d
kube-system   replicaset.apps/coredns-86f78bb79c                  1         1         1       3d20h   coredns                   coredns/coredns:1.6.6                     k8s-app=kube-dns,pod-template-hash=86f78bb79c
ubuntu@Node-1:~
I've enabled DNS, ingress and the (local) storage provider.
