MSD devices
A project log for Project Dandelion
Ubuntu 21.10 with microk8s/1.21.6 on Raspberry Pi 4
carboncycleCarbonCycle 10/17/2020 at 02:120 Comments
I've been building Raspian nodes with external storage for awhile.  I've found the recent changes to the boot eeprom to work just fine to boot from USB. With Raspian.  With Ubuntu - not so much. At this point, I consider it a bit of a rabbit hole.   So I'm fine with booting initially from the MicroSD card.  It doesn't get mounted - and that is perhaps a good thing as I can still debug a boot problem separately from the state of the MSD device.
The downside is that after kernel rebuild - that kernel is not installed automatically.  So I'm a few revisions behind already.   Resolving this issue with automation is currently deferred.  Once I figure out a manual method that is reliable - I'll document that here after some testing.
Another note is the hardware used.  The PCI-e to USB bridge boards I'm using use the RTL9210B-CG chip on a generic adapter.   The good thing is: no heat issues. At all.  The problem?  The device has a firmware setting that turns off power ( IOERROR! ) after 10 minutes of no access.  The upside?  Microk8s hammers that disk regularly - so as long as Microk8s is running properly - the disk stays on.
I disable all that power stuff ( to no effect, apparently ) with:
 - Disable sleep
sudo systemctl mask sleep.target suspend.target hibernate.target hybrid-sleep.target
  - Re-Enable sleep
sudo systemctl unmask sleep.target suspend.target hibernate.target hybrid-sleep.target
