Assembly Run
A project log for Pick-and-Place Machine
A custom-built pick-and-place machine running OpenPnP.
LanceLance 11/06/2021 at 15:170 Comments
Running a PCB on the Machine
After a lot of work, testing, debugging, and fixing, the machine is up and running and capable of assembling a PCB.  There's still work to be done to make things easier to use.  A new strip feeder design is likely.  Rearranging the build table is coming in the near future.  Overall, though, the machine works well and is really accurate.
