Design Updates
A project log for Pick-and-Place Machine
A custom-built pick-and-place machine running OpenPnP.
lanceLance 03/22/2022 at 21:560 Comments
Introduction
After building and testing the machine, I started to notice some limitations, small design issues, and areas where improvements could be made.  Several iterations later, I have an updated design that smooths out these rough edges.
Many of these are significant and will get their own log entries like a completely new head design, PCB holder, custom light, and nozzle tip holders.  Stay tuned in for those.
Below are a few additional updates.
Here are some updated images of the machine.
Machine Top
The top of the machine.
Machine Bottom
The bottom of the machine. The electronics are mounted to the bottom of the build plate.
Removed the LCD Screen
After testing with the LCD screen, it was determined it added little value to a pick-and-place machine.  Unlike a 3D printer, a pick-and-place is always connected to a computer.  All of the information that the LCD screen would be used for is available on the computer and easier to access.  The emergency stop button was integrated into the original LCD screen mount, therefore, a new stop button holder was designed.
Camera Changes
The bottom camera was horribly mounted in the middle of nowhere.  The consequences of this became apparent almost immediately.  A shorter focal length was chosen to both allow the camera to be closer to the build table while maintaining the field of view,   This also allowed the same cameras to be used for both the top and bottom.
