Hackaday.io Hackaday.io
Sign up Log in
Reviving the TI-92 calculator into a RPI PC
We are re-engineering the old PCB board into a modern PCB for a simple swap. The goal is to get an up to date RPI computer
pcadicpcadic
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
9.6k views
17 comments
85 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 14
    • View all
  • Instructions 0
  • Discussion 17
View Gallery
9.6k
17
85
58
Team (1)
  • pcadicpcadic
Join this project's team
  • TI 92 Reviving project
ongoing project
hardware
raspberry kicad lora
This project was created on 10/18/2020 and last updated 4 years ago.
Description
This project is trying to design a new modern PCB for the old TI92 calculator so a simple swap can be done . Doing this, you will get a fast RPI ZERO or a COMPUTE MODULE 3 PC + a high resolution 4 inch color display. The enclosure of this calculator gives a nice strong keyboard and plenty of internal space to add options: USB SD, Long range radio modules, sound etc ...The TI-92 calculators can be found easily on <a target="_blank" rel="noopener noreferrer" href="http://ebay.com">ebay.com</a> at around 20-30 USD. The way they are built allows and very easy opening and components swaping. This project is made with Kicad, a bit of Solidworks. We need you help to speed up the process...<br><br>All source files are in our github directory (see link below).
Project Logs
Collapse
  • Project back on desk
    pcadic • 12/08/2021 at 14:04 • 1 comment
    After a pause, I'm back on the project. I was waiting for a good color display. WaveShare has released a cool 800x480 IPS color touch display (4 inch). This one seems to fit well into the re-visited pc board.
    Tonight we are going to test the freshly received display with our selected Raspberry PI ZERO 2W . If ok, we will adapt the board and send to production
  • Hackster.io article
    pcadic • 10/27/2020 at 08:36 • 0 comments
    Hackster.io has published a detailed article about this mod.
    https://www.hackster.io/news/in-search-of-the-perfect-portable-pocket-terminal-sometimes-there-s-no-school-like-the-old-school-a20ef49d2082
  • Low power power switch
    pcadic • 10/22/2020 at 21:53 • 0 comments
    Preparing to add a very low power switch...
  • XTP2046 & RPI install
    pcadic • 10/22/2020 at 21:14 • 0 comments
    I found the source to use the XTP2046 chip with the RPI PI ZERO
    The Datasheet is here
  • Experimental schematic diag
    pcadic • 10/22/2020 at 21:09 • 0 comments
    I had to revert KICAD back from nightly build to stable and lost a pqart of the work because of file down compatibility issues. I had to redo the routing.
    Here is the first experimental schematic diagram (still some work to do).  Until I get a Compute module 3, I will use the RPI PI ZERO W computer.
    Next step tomorow
  • Voyage 200 board , similar
    pcadic • 10/21/2020 at 18:54 • 0 comments
    I also got the Voyage 200 model which replaced the TI92. All the work made with TI92 will speed up the conversion process  for the new model
  • Installing linux on the RPI PI ZERO W
    pcadic • 10/20/2020 at 20:15 • 0 comments
    Now trying to connect the 4 inch to the RPI PI ZERO . Looks like this tutorial will ease the process . Shows how to install ST7796s on raspbian. The website also offers pre-compiled images.
  • Keyboard footprint and connections are ok
    pcadic • 10/20/2020 at 19:54 • 0 comments
    I tried to route a bit... everything seems ok. There is much room to work with security and comfort.
    Before I finish the routing I have to finish the schematic with the RPI stuff.
    Time to read on how to drive the display with the RPI ZERO and RPI CM4 .
  • Footprint correction
    pcadic • 10/20/2020 at 15:31 • 0 comments
    oups, thanks to you for the comment
    There was a mistake in the buttons footprints
    I corrected the button mistake ... and updated the files
  • Current progress with KICAD
    pcadic • 10/20/2020 at 14:28 • 0 comments
    I've just updated the GITHUB directory with the latest kicad dev (please is the last nighly built of kicad to open the files)
    I added the buttons on the board.
    It is not time to work on the raspberry pi zero and  RPI Compute module 4 add.
View all 14 project logs
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
Jamie Nichol wrote 02/09/2023 at 00:12 • point
I have a circuit board designed and fabricated for the TI-92.  It fits beautifully, and I'm bogged down doing board bring-up and could use some help.  I'd love to share the board design here.   Can anyone accept my application?
Jamie Nichol wrote 10/26/2022 at 15:01 • point
Hey everyone, I would like to contribute to this project.  My application status is 'pending' for the past few days.  Any suggestions?
Cees Meijer wrote 10/26/2020 at 20:52 • point
Just for fun, check out this page with  a beautiful mockup image of the TI92, which might even serve as an inspiration: http://androidarts.com/palette/Misc.htm
Jamie Nichol wrote 10/21/2022 at 13:58 • point
Love it.  Wish the TI-92 had the d-pad on the other side.
Jacob B wrote 10/22/2020 at 12:34 • point
Is the screen on the Voyage 200 identical to the screen on the TI92? I have a TI92 on the way but it does look like the voyage 200 is a slightly larger screen, or is that just an artifact of the photo angle?
pcadic wrote 10/22/2020 at 21:01 • point
I've not yet opened the voyage 200 to keep all my energy on the TI92 dev/ But at first glance, it is the same display.
Jacob B wrote 10/22/2020 at 21:18 • point
Thanks, I have a ti92 on the way but haven't bought anything else until it gets here. But if it would require opening to know that suggests the Voyage isn't significantly larger if it is larger at all, so that pretty much answer my questions right there.
feiltom wrote 10/21/2020 at 12:17 • point
Very good idea !, I buy TI92 and the LCD this morning.
Jacob B wrote 10/20/2020 at 19:02 • point
Am very interested in this project. I was playing around with the thought of shoving a pi4 into a nspire, a little more incognito, but this also looks very interesting.
<strike>Is the plan to find a touchscreen for mouse input, or maybe use the upper right hand pads to create mouse input?</strike>
Ahh, nevermind, touchscreen.
Pavel Brychta wrote 10/20/2020 at 15:09 • point
Please check your 6mm pad footprint - there is short circuit between P1 and P2 (second vertical trace from right on lower half)..
pcadic wrote 10/20/2020 at 15:19 • point
Thanks for the remark.  ahhhhhh correcting
Dan Maloney wrote 10/19/2020 at 21:15 • point
The donor calculator seems to offer a lot of space to work within. Looking forward to seeing what you come up with.
Cees Meijer wrote 10/19/2020 at 15:17 • point
Awesome! And these calculators are indeed very cheap on ebay, so I definitely consider making one as well.
pcadic wrote 10/19/2020 at 15:22 • point
yes. They were also widely distributed ... :)
Cees Meijer wrote 10/19/2020 at 19:16 • point
Well, I never saw one before, but I suppose that's an age thing. Every generation has it's own calculator :-)
pcadic wrote 10/19/2020 at 19:43 • point
yes. They are rather old. I remember using it with RAMSES II in class :)
Richard Hogben wrote 10/19/2020 at 14:28 • point
TI-92 memories...
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Reviving the TI-92 calculator into a RPI PC", please tell us the reason.
Send message
Remove Member
