I found the source to use the XTP2046 chip with the RPI PI ZERO
The Datasheet is here
A project log for Reviving the TI-92 calculator into a RPI PC
We are re-engineering the old PCB board into a modern PCB for a simple swap. The goal is to get an up to date RPI computer
