Voyage 200 board , similar
A project log for Reviving the TI-92 calculator into a RPI PC
We are re-engineering the old PCB board into a modern PCB for a simple swap. The goal is to get an up to date RPI computer
pcadicpcadic 10/21/2020 at 18:540 Comments
I also got the Voyage 200 model which replaced the TI92. All the work made with TI92 will speed up the conversion process  for the new model
