Finished Wiring
A project log for CHANGER - a toolchanger new interpreted
CHANGER - a motion system which can be used for advanced 3D-Printing with up to four materials, PnP, PCB-Milling, Layer inspection, etc...
simon-wirzSimon Wirz 06/23/2021 at 18:280 Comments
Wiring the Tooldocks:
I've finished the wiring harness for the tooldocks. I've tried to keep it tidy but with the chance to quickly remove the individual tooldock-harness for easy maintenance.
Configuration:
I've configured all the fans (Heatsink, Partcooling etc.) like already mentioned in the last project-log. I added a 10K Temp.Sensor for the watercooling cycle so I'm currently using all of the thermistor inputs on my Duex5. You can add all of the Temp. Sensor to the temperature log in the Duet Webcontrol/-server which looks like this:
Because I've installed just one working tool there is only one correct temp. value for the tools 0 to 4. The temperature of the watercooling loop is monitored as well.
