Topcover is taking shape
A project log for CHANGER - a toolchanger new interpreted
CHANGER - a motion system which can be used for advanced 3D-Printing with up to four materials, PnP, PCB-Milling, Layer inspection, etc...
simon-wirzSimon Wirz 03/09/2022 at 11:080 Comments
The started building process of my third topcover design is slowly taking shape:
https://hackaday.io/project/175489-changer-a-toolchanger-new-interpreted/log/203393-continuing-topcover-design
After some printing (roughly 60h) there's some progress visible...
Some impressions:
All parts are designed in a way that there are minimal supports needed as you can see in the picture above. This angle without support and 0.2mm layer-height is no problem at all.
The back portion of the topcover is printed and assembled and I think it could look good. I didn't order the panels yet because I want to see if I'm fully satisfied with the look of it.
Front-top part WIP
