Tool-Log: 20W Laser Module (NEJE N30820)
A project log for CHANGER - a toolchanger new interpreted
CHANGER - a motion system which can be used for advanced 3D-Printing with up to four materials, PnP, PCB-Milling, Layer inspection, etc...
simon-wirzSimon Wirz 04/29/2022 at 20:470 Comments
I ordered one the cheapest yet most powerful laser modules which should fit with some minor adjustments to the E3D-Toolchanger toolplate.
The Laser Module:
Check the website for more information about the laser module: https://neje.shop/
The CAD-Design
I've disassembled the laser module and created a CAD-model which can be found here:
https://grabcad.com/library/neje-n30820-laser-module-20w-1
For the module to fit you'll have to adjust the ToolChanger Receiver by removing the ''front part'' like illustrated above:
The link to the E3D-Part: https://e3d-online.com/products/toolchanger-receiver
For the slot feature to work you'll have to adjust the aluminium-profile body of the laser module as well. The implemented laser module will look like that:
Required adjustments
