Sebastian Rocket
A level one certification rocket utilizing 3D printed components
A Tripoli level one certification rocket utilizing 3D printed components, such as:
Motor Mount
Fin Mount
Ballast Chambers
Couplers
Nose Cone*
Parachute attachment
Body tubes used are non-3D printed, made of LOC thick cardboard
With the extra weight added by 3D printing the tubes, along with the layer de-lamination likelihood, it simply does not make sense to print the tubes.
*I ended up not printing the nose cone because I had a commercially-made nosecone laying around and it was a lot easier to not have to design and print one, so boom, nosecone.
Sebastian could potentially carry the first test of the Ariel Flight Control System, a system that can actively control the apogee altitude of a rocket.
This is a rough, low-opacity overview of of the motor mount design:
Not-so-obvious parts are labeled, the rest are easy enough to work out.
  • 1 × Motor Mount 3D Printed
  • 1 × Motor Mount Cap 3D Printed (Holds in the motor, fins, and ballast)
  • 1 × Nosecone 3D Printed
  • 2 × Threaded Coupler 3D Printed (One for nosecone and one for motor mount)
  • 1 × Non-Threaded Coupler 3D Printed
View all 9 components
  • Launch Stuff
    Sir Michael II11/09/2020 at 20:18 0 comments
    So it launched. It wasn't very fun. Or at least recovery wasn't. The wind was about 20-25mph. Sebastian had a 36 inch parachute. About 850 g. After measuring on google earth the drift was around 2.55 miles. After retrieving another person's Level 3 nosecone along the way, the total HIKE was just under four and a half miles. Launched Saturday, late Monday and my feet still hurt. Launch was good, got my Level one certification. 198.5m/s (444 mph), 805.8m (2643 ft). H242-10 motor. Eight foot long 1 inch rail. Honeywell Commercial Launch setup in the background.
  • Launch Tomorrow Morning!
    Sir Michael II11/07/2020 at 02:38 0 comments
    Sebastian will have his maiden flight tomorrow morning in Argonia, Kansas. Pictures and video to follow afterwards. Painted and glued everything today.
  • Rough Fins Mounted
    Sir Michael II10/29/2020 at 18:12 0 comments
    Even though two of the fin prints failed at some level (these two just aren't good enough for 500-600 mph flight), they still serve a purpose as fit tests and looking cool until I get them re-printed. Luckily the process of replacing a fin takes about 11 seconds. Unscrew the cap, slide the fin out, slide the new one in, screw the cap back on.
    Image won't work, maybe later.
  • Parachute Attachment Cross Printed
    Sir Michael II10/29/2020 at 01:32 0 comments
    Printed, ready to glue in. Kevlar string runs through both holes and ties to a carabiner, which the parachute ties to as well.
  • First Fin Printed
    Sir Michael II10/27/2020 at 22:12 0 comments
    Warped just a little, fin tab bent a little, caused some fit issues, fixed.
  • Motor Mount Cap Finished Printing
    Sir Michael II10/27/2020 at 20:23 0 comments
    Fits like a glove. PLA instead of ABS.
  • Sebastian Virtual Mockup Finished
    Sir Michael II10/27/2020 at 06:51 0 comments
    I think it looks pretty slick.
  • Cap Design Done
    Sir Michael II10/27/2020 at 06:50 0 comments
    Finished designing motor mount cap, will print tomorrow.
  • Fin Mockups and OpenRocket Design Finished (ish)
    Sir Michael II10/27/2020 at 05:56 0 comments
    Reasonable stability margin and a good look, Sebastian has only a few more parts before final assembly starts. Looking around Mach 0.8 on maximum velocity and around 1,000m apogee.
  • Threaded Coupler Printed
    Sir Michael II10/21/2020 at 01:36 0 comments
    The original 35mm threaded coupler was extended to 37.5mm to work with threads leaving a 2.5mm gap between the coupler and the motor mount. Tolerance was adjusted after the first print for a tighter fit. *Quietly Laughs*
View all 11 project logs
