The original 35mm threaded coupler was extended to 37.5mm to work with threads leaving a 2.5mm gap between the coupler and the motor mount. Tolerance was adjusted after the first print for a tighter fit. *Quietly Laughs*
A project log for Sebastian Rocket
A level one certification rocket utilizing 3D printed components
