Fewer parts - easier to print!
A project log for The Ball-Drone Project MK II
Single rotor, "singlecopter", selfmade drone with air vanes for position control as a full remake of the Ball-Drone Project
benjamin-prescherBenjamin Prescher 10/23/2020 at 13:450 Comments
In the end, The Ball Drone (MK I) had a lot of components and was correspondingly heavy. The current version shows itself with significantly fewer components, which can also be printed easily and usually without support material ...
