PressurePlate.scadSee STL descriptionscad - 747.00 bytes - 10/30/2020 at 21:40 |
PrintHead_09.scadSee STL description. This has a three major part defined, lines must be uncommented to create the STL separately for the back plate, the top grill and the template for the aluminium heat sink.scad - 7.31 kB - 10/30/2020 at 21:39 |
PressurePlate.stlThis slides along the top rail of the X-Axis rails and pressurises the head against the top rail. Ths in turn controls how hard the nozzle is held against the print job and how much pressure is required to activate the Z-Axis switch.Standard Tesselated Geometry - 66.28 kB - 10/30/2020 at 07:16 |
PrintHead_09.stlThe large blue wedge that mounts the new Print Head assembly onto the X-Axis gantry slider. It holds the back heatsink, which holds the hotend. The Cooling fan and extra heat sink is mounted on the backplate heat sinks. It also house the pressure plate system that controls the pressure required to activate the Z-Axis limit probe.Standard Tesselated Geometry - 374.72 kB - 10/30/2020 at 07:15 |
backplate_09_template.stlThis is a template for the 3mm aluminium plate used for the main heat sink.Standard Tesselated Geometry - 241.26 kB - 10/30/2020 at 07:15 |
TopGrill.stlA bit of bling in some ways but now has the job to hold the spring that presses on the Pressure plate.Standard Tesselated Geometry - 51.80 kB - 10/30/2020 at 06:50 |
