W8’s Sunday: Continue with the designing of the Plate Holder and how to move it with a motor; Designed and built gear holder to help with the movement of the plate and the belt; measured and laser-cut the top panel of the micro plate reader; learned about the programming for controlling the movement of motor and the turning on and off of the LED
