Importing Files
A project log for Kyazuken: a Java-like language
Java is great. Could I roll my own?
Dylan BrophyDylan Brophy 10/29/2020 at 00:410 Comments
Well, it's reading files I import.  Which is good.  Now I just need to make them parse...
And here's what was failing:
class Lexer {
	File file;
	String buffer = "";
	int line_number = 0;
	Lexer(File file) { // line 10
		this.file = file;
       .... more code ....
It's the constructor.  I forgot to put a access restriction like 'public' or 'private' on it.  My parser must think it's manditory.  Debating weather it should be.
One thing I don't care for in Java is that the default access has no keyword.  It's not *bad* but it seems like better code would be produced by requiring one.  Just thinking.
