SIO and Sound Board
A project log for MSX COMPATIBLE BOARDS FOR RC2014
Create a series of boards designed for the RC2014 bus to achieve MSX/MSX2 compatiblity
dean-nethertonDean Netherton 12/29/2020 at 03:190 Comments
RC2014 SIO/2
Managed to get the RC2014 SIO/2 Board to work with my MSX rig.
Its took a bit of finessing to get the higher baud rate (57200) working with MSX BIOS interrupt handler - the overheads make it easy to lose data.
The application talks directly to the SIO chip.   A future goal will be to integrate the serial driver within the BIOS/Nextor systems.
Sound/Controller Board
After a few bodge fixes - i was able to get the sound board working (YM2149 chip).  I considered using the RC2014 Sound board, but I don't think the revision I have supports the MSX ports.  A later revision seems to.
The board I designed, also support controller ports -- if only I owned a MSX controller!
(The missing chips are required for the controller ports - will install when i get an MSX controller to test with)
In the next few days, I will try and get myself organised, and upload designs.
In the meantime you can watch me playing PACMAN really badly.
