Backplane and Cartridge Extension
A project log for MSX COMPATIBLE BOARDS FOR RC2014
Create a series of boards designed for the RC2014 bus to achieve MSX/MSX2 compatiblity
dean-nethertonDean Netherton 11/01/2021 at 23:090 Comments
One of the developments that been wanting for time, is the development of a custom backplane and cartridge extension.
In the picture above, you can see the 13 slot backplane, where the 13th slot connects to the Cartridge slot exertion board, with a custom built cartridge (flashed with pacman).
The backplane extension provides 2 buffered MSX cartridge slots.
Now in this configuration, all seems to work - but I have not been able to test with an original cartridge - so its very possible I have a compatibility issue, that I don't understand/failed to implement correctly.
I have some original cartridges coming from Japan and Europe - and also a couple of modern cartridges coming the msxcartridgeshop
So until they arrive - I can not have any confidence that implementation does not have some compatibility issue.
The main backplane has the full 80 lines (2x40) bus lanes, and avoids the need to use jumper wires between some of the modules when using the standard backplane.  It also have a bunch of LEDs between each slots, giving the whole kit a nice soft glow when powered on!
