2d sculpture out of brass rodes
The metal king
took the print out of the sculpture pattern in a paper in the required dimension
Made 5 brass rodes with 30cm length each.
Placed the brass rodes on the top of the patter and made the required shape by cutting and bending the brass rodes with reference to the pattern.
View all 5 instructions
David Hopkins
lion mclionhead
Maarten Schipper
Yes, delete it Cancel
You are about to report the project "The metal king", please tell us the reason.
