Version 4
A project log for USB volume knob
A knob to control the volume on my PC - with RGB
nagupnagup 06/17/2021 at 21:310 Comments
I have managed to think of a way to add better indents to the turning action. The PCB is in progress but the housing is nearly complete, currently printing the parts out for their first test.
Major changes include:
- Large bearing to help prevent the knob from tilting and to make the turning smoother
- More substantial indent feedback, the force is also adjustable, will not wear down like the built-in one in the encoder (it is weak also)
- Using threaded inserts
- Encoder attached to the PCB itself and the body cover giving two anchor points
You can also see an animation of how the indent mechanism works
