Elegoo 37 sensor kit
Review of the Elegoo 37 sensor kit v2.0
1.2k views
0 followers
Few days ago, the nice folks at Elegoo sent me a Elegoo 37 sensor kit v2.0. I'll review some of the sensors in that page, using an Wemos D1 esp8266.
Few days ago the great folks at Elegoo sent me a nice 37 sensor kit in v2.0.
It includes :
  • A double voltage power supply
  • Temperature and Humidity Module
  • DS18B20 Temperature Sensor Module
  • Button Switch Module Switch Module
  • IR Receiver and Emission Module
  • Active Buzzer Module
  • Passive Buzzer Module
  • Laser Module
  • SMD RGB Module and RGB Module
  • Photo-Interrupter Module
  • Two Color LED Module
  • Light Dependent Resistor Module
  • Large Microphone Module and Small Microphone Module
  • Reed Switch Module
  • Digital Temperature Module
  • Linear Magnetic Hall Sensor Module
  • Flame Sensor Module
  • Touch Sensor Module
  • Seven-Color Flash LED Module
  • Joystick Module
  • Line Tracking Module
  • Obstacle Avoidance Module
  • Rotary Encode Module
  • LCD Display
  • Ultrasonic Sensor Module
  • GY-521 Module
  • HC-SR501 PIR Sensor
  • Water Level Detection Sensor Module
  • Real Time Clock Module
  • Keypad Module
Also, a mini CD contains tutorials, datasheets and code example.
It’s very complete.
  • 1 × ELEGOO 37 in 1 Sensor Modules Kit https://www.elegoo.com/collections/arduino-learning-sets/products/elegoo-upgraded-37-in-1-sensor-modules-kit
View all 5 project logs
