Added a new holiday wreath shader to celebrate the holidays!
Also, I've tested the Busy/Free Desk Indicator with CircuitPython 6, and it doesn't like having the Circuit Playground's filesystem mounted in read-only mode. If you would like to use CircuitPython 6 then omit boot.py when installing the software - otherwise stick with CircuitPython 5.3.
DeckerEgo
