Added a Holiday Wreath Shader!
A project log for Busy/Free Desk Indicator
A busy/free desktop indicator for the Adafruit Circuit Playground Express. Red shows you are busy and for how long, blue shows you are free!
deckeregoDeckerEgo 11/28/2020 at 01:080 Comments
Added a new holiday wreath shader to celebrate the holidays!
Also, I've tested the Busy/Free Desk Indicator with CircuitPython 6, and it doesn't like having the Circuit Playground's filesystem mounted in read-only mode. If you would like to use CircuitPython 6 then omit boot.py when installing the software - otherwise stick with CircuitPython 5.3.
