CAN Bus Id's
A project log for Bluetooth For 2008 Chrysler Grandvoyager
Bluetooth that actually works...
saabmanSaabman 11/24/2020 at 22:140 Comments
After not getting anywhere with the 0x3F5 ID although it is related (sends display information to the Head Unit - there had to be some other related ID that switched the head unit.
Thanks to the work done by BiggRanger I was able to use the time ID 0x3E6 as a reference to refine the point at which I activated a phone call and could look back from the 0x3F5 "Connect" string a few seconds.
The amount of data on the bus is quiet a lot even when the ignition is just in the accessory position and nothing being activated there is around 200 messages a second.
