• 1
    Download Grbl Laser Post Processor
    Go to Autodesk's Post Processor website, enter "grbl laser" in the search box and download it.
    Keep this in a semi permanent path, we will need to point to this file later.
  • 2
    Design it
    Design your cuts in Fusion 360.  It could be a sketch, or a solid. We will specify which edges to laser cut later.  if you decide not to extrude your object, you might want to create a solid around the sketch so when we simulate a cut, you would see it cut something.
  • 3
    Create Setup for the laser cutter
    Switch to Manufacture workspace in Fusion 360
    Create Setup for Generic Cutting Machine
