ERM19264 UC1609C LCD library
Arduino Library to Support the ERM19264 LCD driven by the UC1609C controller.
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
Title : Library for ERM19264-5 v3 LCD (UC1609C controller) for the Arduino eco-system
Description :
Arduino library.
Inverse, rotate and contrast control.
ASCII text strings and character text display.
Graphics library included based on the Adafruit GFX library.
Sleep mode.
3 different modes: Multi-buffer , single buffer , light weight text only
custom bitmaps supported.
Author: Gavin Lyons
Arduino IDE: 1.8.10
Tested on following MCUs both software and hardware SPI, The example files are setup for an UNO for the pin connections used by for other MCU testing see extras folder GPIO_MCU_used.txt file.
