About
The power controller circuit is just a simple electronic on/off switch, two illuminated buttons on the right control which soldering iron will be on, in the center there is room for 0.96" OLED display. The circuit will be able to measure total current draw and voltage on the output, and display it on the OLED screen. I had an idea of making custom soldering iron cables, that would include a barrel connector and a USB connector, so data could be sent and received from soldering iron itself, but this is V1.0, maybe in some future version. Left side of the enclosure has two square openings, meant for holding down the output power cables, and just below them, there is a banana jack, that can be used for ESD protection bracelet. The power supply unit is off the shelf switch mode power supply module WX-DC2416 24V/6A.
Nikola Secerovski
