The usual disclaimers apply here: Don't try this at home, I'm not responsible if you burn your house down, etc.
I don't leave the heater running when I'm not there. It wouldn't do any good anyway. It's a radiant heater meant to heat you directly, not the room.
The parts list is just what I used. You may want to try a different power supply since I ran into some issues with the one I picked.
compukidmike
Jake
tobychui
alnwlsn
Yonghan
When looking for a projector to use as a gaming monitor, it is important to make sure the size of the screen matches your needs. This article will tell you how to find the Best Projector Under 250 and what features are important when making this purchase decision. It will also list some of the models we recommend based on research and reviews from other consumers.
