Volumetric: Wi-Fi LED strip controller
Wi-Fi LED strip controller that works well
Public Chat
Starting from
$29.00
kumekay has 2 orders / 0reviews
Ships from Czechia
Wi-Fi LED strip controller that handles up to 17 Amps of load, doesn't flicker, doesn't squeak and can be used with Google Assistant, Alexa, Home Assistant or other services through HTTP API or MQTT.
Wi-Fi LED strip controller made with few goals:
  • Dual voltage support 12V and 24V
  • 2 independent channels for color temperature adjustments
  • No high pitch noise in all modes
  • Powerful enough to handle current up to 17.5A (in total, limited by connectors)
  • Control buttons on the device body
  • Connectors for external buttons
  • Can be used with already installed LED strips
  • Support of open source firmware, like https://esphome.io/
  • The new revision
    Sergei Silnov07/03/2021 at 11:24 0 comments
    Look at these little babies: esp32-c3-mini: riscv core wifi+bt and a bunch of security features. This module is the heart of the new revision for volumetric one led strip controller
  • Source. Open source
    Sergei Silnov12/03/2020 at 21:51 0 comments
    Source is open now.
  • More boards
    Sergei Silnov11/26/2020 at 08:50 0 comments
    More boards are ready and tested.  Will list them on tindie.com by the end of the week
  • That's the case
    Sergei Silnov11/23/2020 at 10:50 0 comments
    The controller has a case now. It's 3d printed with two colors to highlight connectors pinouts. Lines also emphasize two buttons on the top surface.
    The button's connector on the side is labeled too.
    Simple rounded corners don't look in all lighting conditions because of curvature between the circle part and flat side jerks. And the way to the perfect shape is long. Here I used Bezier curves that make curvature smoother.
    The case and accent color may vary.
  • First completed board
    Sergei Silnov11/20/2020 at 22:08 0 comments
    First board hardware is finished and it works in full range of voltages from 5V to 24V. On the picture it's loaded with 100W load at 24V.
  • It works.
    Sergei Silnov11/17/2020 at 23:06 0 comments
    Components required for DC-DC and support of 24 volts are not delivered yet. But everything else is here and I baked first couple boards.  Blue wire is a temporary shortcut to make tests possible.
    Board stays cool when loaded for 7A (85W). For brightness regulation I use LEDC peripheral of ESP32. It can handle 512 levels for smooth level changes. Base frequency is 80KHz and noise is inaudible for humans.
  • Boards and case
    Sergei Silnov11/16/2020 at 11:48 0 comments
    Boards were delivered today and look good so far. Components are still on the way, so first boards for the tests will be by the end of the week.
    At the same time first version of the case was made and it  fits well without any screws.
  • First batch is sent to production
    Sergei Silnov11/12/2020 at 14:41 0 comments
    The board was sent to production at JLCPCB and components were ordered. This batch is designed to use both components sourced in China, like XL1509 DC-DC converter and western ones, like MIC4127 MOSFET driver
    Depending on how successful will be this initial design after first tests, up to 30 board will be produced in this batch. Do you want one to try?
View all 8 project logs
[deleted]
Sergei Silnov wrote 11/12/2020 at 20:46 point
Hello,
I attached current schematics to the post,
Output terminal is  GND_1 | V+ |  GND_2 | V+
It is made this way to control either 2 independent single color LED stripes, or to control one with Warm white/Cold white LEDs
