It works.
A project log for Volumetric: Wi-Fi LED strip controller
Wi-Fi LED strip controller that works well
sergei-silnovSergei Silnov 11/17/2020 at 23:060 Comments
Components required for DC-DC and support of 24 volts are not delivered yet. But everything else is here and I baked first couple boards.  Blue wire is a temporary shortcut to make tests possible.
Board stays cool when loaded for 7A (85W). For brightness regulation I use LEDC peripheral of ESP32. It can handle 512 levels for smooth level changes. Base frequency is 80KHz and noise is inaudible for humans.
