Hackaday.io Hackaday.io
Sign up Log in
Android Resin 3D printer
use android device as the control system of the resin printer
markmark
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
4 comments
17 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 2
    • View all
  • Instructions 0
  • Discussion 4
View Gallery
581
4
17
5
Team (1)
  • markmark
Join this project's team
ongoing project
This project was created on 11/11/2020 and last updated 5 years ago.
Description
Make it easy to build your own Resin 3D printer with android device. 1,install PandaDLP.apk on your android device(android pad,phone,raspberryPi),no need root permission,but need to replace the LCD backlight to UV light. 2,connect the shield board to your android device with usb line. 3,connect the fans,UV light,power,z axis motor to the shield board.
Project Logs
Collapse
  • test with raspberry pi
    mark • 12/07/2020 at 04:04 • 0 comments
  • Testing with my android Phone
    mark • 11/21/2020 at 11:53 • 0 comments
View all 2 project logs
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
akashkdp64 wrote 01/07/2023 at 20:24 • point
How can I make a project?
akashkdp64 wrote 01/07/2023 at 20:22 • point
Love this website what is issue with project
greyss jhtj wrote 04/13/2021 at 03:00 • point
Looks cool. I want to share this project on my Android blog, you can see here https://budapk.com/
mark wrote 04/13/2021 at 08:58 • point
Thank you! your blog is very great.
this is a project that assist visually impaired people to read anywhere they would like, with the help of a portable, cost effective device.
Project Owner Contributor
Braille reader
bennyBenny
Official Hackaday Prize Entry
Something like a smartwatch, but for my motorcycle handlebar, able to controll the music and inform me about incomming stuff
SmartBAR
crumblefishCrumblefish
Is it possible that certain apps are eavesdropping on private conversations to serve ads? Let’s make a small device to find out
The Unthing
roni-bandiniRoni Bandini
Hyperion 4k smart mirror powered by a RPi2 and a smart phone.
Hyperion Touch Vision (HTV)
jeff-holcombeJeff Holcombe
Going up?
© 2025 Hackaday
Yes, delete it Cancel
You are about to report the project "Android Resin 3D printer", please tell us the reason.
Send message
Remove Member
