FreeTouchDeck
Back to overview
a Bluetooth ESP32 TFT + Touch Macro Keypad
allacmc wrote 10/15/2023 at 23:15 point
I made all the connections on a breadboard.
I downloaded the product firmware and it worked perfectly.
Very happy, it's beautiful and everything works!!
Mohammed Arief wrote 04/08/2022 at 10:55 point
I keep getting a white screen with the TFT. I have bought the correct screen and changed the user_setup.h file.
allacmc wrote 11/01/2023 at 03:27 point
The white screen is because the pin to turn on the bottom LED has been turned on, it is HIGH.
You need to check all SPI connections and try to run at least some example of the ILI9488 on the ESP32.
And see if it works....
