Edit wificonfig.json no longer necessary before upload
A project log for FreeTouchDeck
a Bluetooth ESP32 TFT + Touch Macro Keypad
dustin-wattsDustin Watts 03/22/2021 at 21:520 Comments
Since version 0.9.11 it is no longer necessary to edit the wificonfig.json file. If you leave everything as default, when you start the configurator it will start an Access Point. You can connect this access point and change you WiFi settings there!
