The goal was to show how little you have to do to do a fairly feature rich carrier board for the Compute Module 4. Also to demonstrate that you don't have to be scared by high-speed signals like HDMI and that they can still work fine in very bad conditions like a single layer PCB like this one without a reference plane underneath.
Please only use this as a starting point if at all and take a look at the open reference design by the Pi foundation for a more in-depth carrier design. This design skips several saftey features like load switches on the USB and HDMI, most of the time that's fine but you should make sure that you really don't care about that.
Also do please attempt to do some impedance matching. An online calculator to get the correct trace width is already an ok approximation for most use cases.
4 Layer PCBs are to be had for 5$ and less now a days.
It is just amazing how far we've come in terms of diy homemade engineering, thanks for sharing. I have a question about the usb connection: I see that you left the otg_id floating, does the raspberry pi acts as a host or a device in this case? I'm thinking of connecting the otg_id to a microusb id pin, but I saw in the documentation that the otg functionality is not fully implemented. My idea is to use a single microusb connection as a device and also as a host with an usb A adapter.
Very nice project😊!
I am a beginner in PCB designing. Would you list down the name of the used components in the board
Thanks in advance
