Thermoelectric Power Harvesting Demo
Harvesting power from a low cost Peltier heater, run in reverse, to power an embedded electronics demo board
Seebeck effect thermoelectric generators are very inefficient, but with appropriately low power electronics, that's fine! This project shows a demo of boosting the voltage from a single thermoelectric generator using the TPS61200 to charge supercapacitor and run my ATSAML21-based ultra-low power demo board.
Logs:
  1. Power Profiling
  2. Powering a Development Board
  • Powering a Development Board
    Jake Wachlin • 11/14/2020 at 02:51 • 0 comments
    With the custom PCB in hand, I set the thermoelectric generator up in the same way, with a temperature differential of about 40 deg F.
    The output of the TPS61200 is set to be about 2.1V. Note that most of this PCB is for a variety of other projects. Only the bottom left section with the boost converter is relevant here.
    The output is connected to the battery input on my ultra-low-power development board, which charges up the onboard supercapacitor. Note that I taped over the solar cells on the development board, so that they do not contribute to the available power.
    With the system running for only a few minutes, the supercapacitor was charged up, and the development board was running, evident by the periodic flash of its low-power LED.
    In summary:
    • Low-cost Peltier plates can indeed power low power electronics with a simple boost converter setup
      • Even with a minimal temperature differential of about 40 deg F
    • Maintaining a constant temperature differential across the TEG over time is key to long-term functionality
  • Power Profiling
    Jake Wachlin • 11/14/2020 at 02:37 • 0 comments
    The first step to determining the usefulness of low-cost Peltier cooler plates as a thermoelectric generator is to profile the available power. I set up a single plate with an aluminum heat sink on one side. The heat sink was submerged in room temperature water and ice cubes were placed on top, as shown in the picture below. This setup has a max temperature differential of about 40 deg F.
    I built a small adjustable load with a MOSFET in its linear region. I ran a few IV sweeps of the TEG. It is clear that the available power reduces over time as the temperature differential is reduced. I didn't carefully record how much time passed between these tests, but it was only a few minutes.
    Note that the peak voltage is quite low, only about 0.6V at a 40 deg F differential. The available power is significant, at least for ultra-low-power electronics. At peak, I measured 15mW. My ultra-low-power development board required only about 0.38mW in active mode, and much less with some sleep cycles. This encouraged me that I could extract enough power from this TEG, even with the poor efficiency of the Seebeck effect and potentially poor impedance matching to the TEG.
    To boost the ~0.3-0.5V up to a useful voltage, I selected the TPS61200. While not specifically an energy harvesting product, it has a low input voltage of 0.3V, low quiescent current of 55uA, and can boost up to 5.5V. It is also available on JLCPCB for a low cost.
    I designed and built a PCB with JLCPCB that consisted of sub-circuits for a variety of projects, this being one of them. I set up the TPS61200 to boost up to about 2.10V
View all 2 project logs
