reTIL needs a testing socket!
A project log for reTIL
Modern take on TIL311 and reimagination of #PICTIL optimized for easier production and lower part count
alexAlex • 02/07/2021 at 02:07•0 Comments
Of course you could just use a standard Textool dip test socket, but this is boring and brings the risk of rotating it 180°. So I measured the top plate of a Textool socket to print a new customized top plate on a SLA Printer. Not needed contact are removed and holes are nicer fit for the round pins.
The extra hole is for the a extra test pin, This need for rev2 PCBs, but ore on that soon.
