Wi-Fi signal strength LED indicator
WEMOS D1 mini ESP8266 project
LED indicator visually shows you the received signal strength RSSI in dBm from a Wi-Fi router. The indicator is implemented using three LEDs:
- green LED is used to indicate a good signal strength (-60...0 dBm),
- yellow LED is used to indicate a medium signal strength (-75...-61 dBm),
- red LED indicates a poor received signal strength ( < -75 dBm).
x-python - 621.00 bytes - 11/17/2020 at 19:18
Download
  • 1 × Wemos D1 mini on esp8266 board
  • 3 × 3 LEDs (red, yellow and green)
  • 1 × Resistor 330R
  • 1 × Breadboard Electronic Components / Misc. Electronic Components
  • 1 × Wires
