adding a trackpoint to the Keyboardio Atreus
Yesterday i made a proper bracket and screw holes to the atreus so the leds are now held in place by a 3d printed part that also improves diffusion, making the light from the leds melt together and dims the leds enough to have settings other than the absolute minimum actually make sense.
The diffuser layers are about 6mm from the mounting plate and .8mm thick (though that does dim the leds a lot, its fine for me but the repo default is .6mm).
The old, hot glued solution was falling appart and the screws should make it a lot more solid now.
The repository has already been updated and i will add the new photos right after publishing this.
Oh, T530 as well? That's pretty recent. Cool. Thanks.
no more recent than any of the others. the second number indicates the generation.
Never mind- I found your GitLab link on the left. Thanks.
I see some trackpoints available online but soldered onto another board making it USB. If I unsolder it, it seems like its the same "shape" but it has a smaller chip mounted. SurnQiee makes one and Zyyini makes it too. Would these work if unsoldered?
