better mounting for the LEDs
A project log for Keyboardio Atreus tackpoint mod
adding a trackpoint to the Keyboardio Atreus
erisEris 02/16/2021 at 23:370 Comments
Yesterday i made a proper bracket and screw holes to the atreus so the leds are now held in place by a 3d printed part that also improves diffusion, making the light from the leds melt together and dims the leds enough to have settings other than the absolute minimum actually make sense.
The diffuser layers are about 6mm from the mounting plate and .8mm thick (though that does dim the leds a lot, its fine for me but the repo default is .6mm).
The old, hot glued solution was falling appart and the screws should make it a lot more solid now.
The repository has already been updated and i will add the new photos right after publishing this.
