Si⅃O - USB-C OPEN SOURCE POWERBANK
A powerbank with USB-C Power Delivery and 4S 18650 charger / BMS
Public Chat
For some time now I have been looking for an open source USB-C Powerbank. I didn't find it so I started my first project.
Preliminary characteristics:
  • 1 quality USB-C connector
  • USB Power Delivery 3.0 dual role
    • Certified integrated solution
    • Source, 5 to 20V, max 45W
    • Sink, 5 to 20V
  • Li-ion charger
    • Buck / Boost
    • Programmable
    • Rated charging current, 1.5A
    • For 4 cells (4S)
  • BMS
    • Programmable
    • Smart fuel gauge (battery health)
    • All protections (Under Over Temp, Under Over Voltage, Short-Circuit)
    • Cell balancing
  • Management by microcontroller
    • Low power
    • I2C / SMBus hardware
    • Maybe integrated into the Power Delivery Controller
  • Possibility to use the battery voltage (Vbatt) to power external projects.
  • 4x quality 18650 cells
Preliminary synoptic:
I will be happy to discuss this project with you!
View project log
Kosma wrote 11/26/2020 at 17:41 point
one small question: I have some battery/acumulators old and new. old have small capacity/size.
Is possible using old and new battery in one time? For example put power to one, net to second, thirth etc.
I would like to put solar panel, battery for my raspberry pi. And using big 12V AND AA recachable AND 18650 etc. And replace/changing in working computer.
Antonin wrote 11/30/2020 at 20:42 point
Hi Kosma. I am not a battery specialist but integrated cell balancing circuits can only handle small differences.
Maybe you can create a battery pack with the old cells and a pack with the new ones and create an automatic battery selector.
Kosma wrote 12/13/2020 at 19:03 point
this is example www.kickstarter.com/projects/451008586/owltac-a1t-endure-flashlight-with-selective-batter
but your charger will be better if can charge different acumulators AA or 18650 or etc.
