Change of name and Layout
A project log for SNAPZZ-ESPIrimenter
Allowing SNAPZZ-modules (M.2) to interface with a breadboard for experimenting. Also featuring STEMMA-QT and SNAPZZ-connect ports.
thorsten-jaegerThorsten Jaeger 04/01/2021 at 17:410 Comments
At some point i retired the "old" (red) ESPerimenter board and morphed it into the ESPIrimenter (blue PCB).
It's more compact, holds the "PICO SNAPZZ" modules (22x22mm) modules only. But also it breaks out ALL "SNAPZZ M2 gen.2" Pins to Breadboard Pins - that is over 40 !!!
