89C52 clock board
A board designed to mate with the cascadable display boards I designed
This is a clock board designed to mate with the 6-segment or 7-segment display boards that I previously published. It interfaces to a DS3231 module for accurate timekeeping. The design is conventional. As there is plenty of room on the board, it supports options, annotated in the schematic. That's why it's not fully populated. The firmware is at Github, see the links.
I managed to get a professional STC89C52 MCU to pose for this picture instead of the WFH model shown in the virtual 3D rendering. Also the PCB insisted on coming dressed in blue soldermask so I had to indulge it a bit. 🤣
Time passes. I was forced to take a many-month break due to renovations on my home. Finally I got around to installing the missing connector and plugging in a test 4 digit display board. You can see the result in the gallery. Sorry for the fisheye distortion, I used my phone camera. I really need to set up a proper photographing environment for my projects. You can see the RTC in one photo. The firmware was tweaked a little, you can see the details in the Github repo but no substantial changes as testing had already been done with the QX-mini51 development board. Now I can finally mark this project completed. I'll probably couple it to the 6-segment display that I built in #6 segments suffice and give it to a friend as a novel memento.
I've added a couple of photos to the gallery of the clock board piggybacked onto the 6-segment display. You may notice that the 0 is not the same as in my project #6 segments suffice . I'm experimenting with using the upper loop as a 0, but it's compromised by the gap in the middle most clearly exhibited by the 5.
  • Refactoring the code for multiple MCU targets
    Ken Yap01/25/2024 at 09:47 0 comments
    As mentioned in #Adventures with a STC89C52 development board  I bought that development kit because it could accept some AVR MCUs that are almost pin-compatible with the STC89C52. This got me thinking of how I could use the couple of ancient AVR chips that I have. Ideally I would like to reuse firmware that I have written and not have to develop from scratch. So as an exercise in learning more about AVR architecture, I decided to see if I could modify the STC89C52 code so that it could be compiled for more than one type of MCU.
    My requirements are:
    • Make it possible to select MCU type with a #define.
    • Restrict the MCU specific code to as few files as possible. This means that lots of #ifdefs in the main functions of the code are not acceptable.
    • Share the rest of the files unmodified. It's ok for these files to contain macro invocations that expand differently depending on the target.
    I went in and hacked at it until I had something acceptable. I was lucky in some respects:
    • The STC89 and AT90S families are similar in that 4 8-bit GPIO ports are exposed. They both also have two timers. If the families had been more disparate, it would have been a harder job.
    • Both avr-gcc and SDCC accept a fairly comprehensive set of C language features, and the differences are easy to use macros to hide.
    • The business logic (which is for a clock) is quite independent of the MCU architecture so large chunks of code contain no hardware specific manipulation.
    • The hardware specific parts of the code only have to deal with GPIO ports, timers, and interrupt handlers. A more complex MCU application might have more MCU specific code.
    Some constants, like those used for time constants for the button UI can be defined in common include files. Other constants, such as the values loaded into MCU registers, are in MCU specific include files.
    The overhead is very acceptable, only increasing the binary size by tens of bytes due to some inline code being turned into functions.
    I noted that for avr-gcc it's ok for static functions to be defined in .h files because avr-gcc is smart enough to not emit code for the body if the function is not used later in the .c file. In SDCC the functions need to be in a .c file and global rather than static otherwise if in a .h file there will be a copy for every .c file it's included in.
    The changes have been pushed to the Github archive.
View project log
