Shelved it
A project log for LiFePO4wered/Pi400
Simplified low cost UPS and battery power for the Raspberry Pi 400
patrick-van-oosterwijckPatrick Van Oosterwijck 12/10/2021 at 20:543 Comments
This project has been shelved because the Pi400 load switch on the 5V GPIO makes it pretty much impossible to reliably power the thing through the GPIO.  Too bad, but not much can be done about it.
Dustin wrote 02/04/2022 at 17:16 point
That is a proper shame. I'm using my Pi 400 as a daily driver and was quite interested in powering it through GPIO for another project. Is it possible to upgrade the fuse?
Patrick Van Oosterwijck wrote 02/04/2022 at 17:48 point
I'm sure it's possible to remove the chip and bridge it.  Doesn't help me since I want to make a peripheral that works with unmodified devices, but it may help you for that project. :)
Dustin wrote 02/06/2022 at 05:08 point
Good to know. My project, PiCarts, is meant for stock devices as well, and a battery back on the GPIO was an idea I put on the back burner. Shelved it after reading your findings here. I may still make one that connects to GPIO for physical mounting, but supplies power over USB. Would work, but not nearly as elegant or proper.
