Moved from GitHub to Codeberg
A project log for Dactyl Lynx
The Dactyl Lynx is a parameterized, split-hand, concave, columnar, ergonomic keyboard - a fork/rewrite of the original Dactyl keyboard.
david-h-bronkeDavid H. Bronke 04/11/2026 at 20:030 Comments
I've been in the process of moving all of my projects from GitHub to Codeberg, and now this keyboard's hardware and firmware, spkb, and my Snowshoe single keyswitch PCBs are all migrated. If you notice any outdated links, let me know!
Aside from that, I've been planning to rework the base pieces of the keyboard to make the tenting angle even more extreme - I've been using it mounted close to vertical for quite a while (see the photo below), but that currently only works with the camera mounting hardware, not the desktop legs. I'm going to be redesigning the desktop legs base to use 3 carbon fiber rods to join the two sides, so I can easily put it together and take it apart, and so I can set it on the desk and use it without it falling over or getting pushed around the desk too much.
