Week 12. New PCBs sent into production
A project log for Raspberry Pi CM4 Сarrier with Hi-Res MIPI Display
An interface breakout board for Raspberry Pi Compute Module 4, permanently attached to a 7" IPS touchscreen display
Igor ShturmaIgor Shturma 02/22/2021 at 05:015 Comments
Igor Shturma wrote 08/01/2021 at 21:02 point
The repo is up!
cyrus wrote 07/01/2021 at 08:05 point
Hello Igor, Well done! I am so eager to see the design files on github repo. Please update me. I would like to support bigger / higher resolution displays like 10" for my smart home project.
Göran Mannberg wrote 05/09/2021 at 08:17 point
Any updates on the project?
Göran Mannberg wrote 02/24/2021 at 08:07 point
Cool project! Can you make an blog entry about the software drivers used/developed?
Igor Shturma wrote 02/25/2021 at 06:18 point
Thank you! Absolutely. It is still a bit in the motion but after the changes settle, the plan is to put together a GitHub repo with everything necessary to reproduce the project.
