Danger!
A project log for MultiBot CNC v2
A low cost 3D printed CNC that can be built with minimal tools yet is capable of great things.
david-tuckerDavid Tucker 04/09/2021 at 03:020 Comments
It's time to talk safety again.  A member on one of the laser forums I follow posted this picture of there shed recently (I hope it's just there shed).  They left there laser (k40) unattended for a moment and something went terribly wrong.  Everyone is ok but they did spend some time in the hospital.
Anyway the point is that lasers and cnc machines are dangerous.  Not just in the lose your eye sort of danger but fire and plenty of other risks.  This is not something to goof around with.  You need to treat it like the scariest saw in the shop.  In fact it is far worse than that because it is automated and will continue to cut or burn long after something goes wrong.
Safety is no joke.  You need to use your brains when building this machine.  It is not my job or anyone elses to keep you safe, that falls squarely on your shoulders.  And it goes without saying but my instructions above are only a guide to how I build my machine, I am not responsible for any harm you may cause to yourself, others, or your property.  Keep safe!
