Skate Shelf
A project log for MultiBot CNC v2
A low cost 3D printed CNC that can be built with minimal tools yet is capable of great things.
david-tuckerDavid Tucker 12/15/2020 at 03:200 Comments
Here is my latest project, a skateboard holder for my daughters room.  I decided to try my hand at carving plywood with some cheap big box store wood I had laying around from a previous project.  My first attempt was a disaster, but after dialing in the settings a bit I managed to get through it with minimal issues.
I was going for a bit of an artistic look, and I wanted something that would not bash a hole in your forehead if you ran into it.  Also, for some reason my daughter wanted it to double as a shelf.
Cheap plywood is tough to work with but I found a few tricks:
I just got some Baltic birch in today, hopefully it carves better than this wood, but still this was passible.
