Death of Dusty
A project log for MultiBot CNC v2
A low cost 3D printed CNC that can be built with minimal tools yet is capable of great things.
david-tuckerDavid Tucker 12/17/2020 at 03:440 Comments
Sad news, Dusty had a catastrophic implosion today, I'm afraid there is no hope for survival.
I guess the vacuum is too strong for the bucket to handle.  It is probably made worse by the two different sized hoses I'm using causing a stronger vacuum draw on the bucket.  I'm also using a lid with a seal on it, things may be better using a cheaper lid with no seal so some air can leak.
Anyway I'm going to use two buckets stacked together to try and add strength.  If that does not work then I may drill a small hole in the lid to reduce the vacuum draw by a bit.
