Lasers part two
A project log for MultiBot CNC v2
A low cost 3D printed CNC that can be built with minimal tools yet is capable of great things.
david-tuckerDavid Tucker 03/02/2021 at 04:250 Comments
So I bit the bullet and ordered a laser and some safety equipment to go with it.  I ordered the following:
I picked the laser module because it was a solid price vs performance.  I have an idea of also picking up a 0.5watt laser module to compare with.  There is a rumor that the smaller modules may be better for engraving because the laser spot is smaller and more square.  I want to see what the larger laser can do first.
The smoke detector may not be the right choice.  The rumor is that you should use a heat detector rather than a smoke detector, I guess we will find out.
Arkipita did a test of various laser glasses from ebay and found that the proper colored glasses did ok with 450 nm wavelength lasers, but they did not do as well as a certified pair of glasses.  I decided to keep the glasses that came with my laser but pony up the money for good glasses as well.  I can use the others as a backup set.
For now I'm going to hold off on the laser bed and vent system till I get a better sense of what is needed.  I suspect you can get by with a minimal bed and smoke may be a small problem or a large one.  I have several ideas but want to know how bad it is before investing heavily in equipment.
Anyway I don't know when it will all show up, but I'm nervous and exited.
